ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Today I had several tests with RC12.
    I flew in: Stabilize, AltHold, PosHold, but that was as far as my test went.  About 4 minutes into Loiter. My Y6 did a hard over to the left and crashed.  I had it running approximately 8 ft off the ground and hands off Radio when it occured.  Not sure what went wrong.
    Here is the Log Analyzer report:
    Log File C:/Users/Doug Walmsley/AppData/Local/Temp/tmpA568.tmp.log
    Size (kb) 1909.208984375
    No of lines 26588
    Duration 0:04:20
    Vehicletype ArduCopter
    Firmware Version V3.2-rc12
    Firmware Hash 6537432b
    Hardware Type
    Free Mem 0
    Skipped Lines 0
    Test: Autotune = UNKNOWN - No ATUN log data
    Test: Balance/Twist = GOOD -
    Test: Brownout = GOOD -
    Test: Compass = GOOD - No MAG data, unable to test mag_field interference
    Test: Dupe Log Data = GOOD -
    Test: Empty = GOOD -
    Test: Event/Failsafe = FAIL - ERR found: CRASH
    Test: GPS = GOOD -
    Test: IMU Mismatch = UNKNOWN - No IMU log data
    Test: Parameters = GOOD -
    Test: PM = GOOD -
    Test: Pitch/Roll = FAIL - Roll (-83.25, line 26117) > maximum lean angle (45.00)
    Test: Thrust = GOOD -
    Test: VCC = GOOD -
    Y6B has been modified with
    Upper Motors 850kv with 11x45 APC props
    Lower Motoros 690kv with 12x8e props
    I've attached the .bin file for review.  Could use some help to determine what happened.
    Thanks Doug W
    2014-10-12 14-02-23.bin
  • Another repeat question. Where would I go to find more information on EKF for Pixhawk?
  • I like STAB throtle control, can climb & descending faster when take aerial photo, but STAB can not hold the position, drift too much. waste time keep correct the postion,
    I try loiter/poshold and increase speed up still dont feel that way. It not fast climb as STAB does.
    Any chance we can increase speed up parameters in loiter till get manually throtle control ?
      I agree, as we have pointed out it's necessary to have a better throttle control in position hold, or to reinstate "Position" flight mode.
