Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Sorry, again - shall I keep the 0 P values after autotune as normal or autotune resulted in incorrect settings?
  • @leonard
      Were you able to take a look at my Auto Tune logs from this discussion?
    http://diydrones.com/xn/detail/705844:Comment:2018277
    Not to sound impatient, but I won't take it up again the way it is.
    Thanks.
  • Hi dev, I have been following the dev. here http://firmware.diydrones.com/Copter/2015-06/
    Up til now there has been updates on the "latest but the last update is 8 june.
    Is it placed elsewhere or?
    in github I can see there has been changes.
    Just of curiosity/ Goran
    • I don't think there are nightly builds per say, i think Randy or one of the devs actually triggers a compile after testing alot of new changes in dev, or else there would be alot of nightly crashes.
  • hi! What does the "EKF Variance" prompt on my HUD means?
    • Hi Erwin
      Doe the EKF VARIANCE warnings come up as soon as you arm?
      • oh well, I got rid of the error by performing calibrations again :)
  • 还有一个问题请教 我的亚拓700e直升机的尾舵机 型号是BLS251 是窄频舵机飞控为什么不支持呢?或者哪里可以调试 谢谢
  • 我用了 3.3rc5 固件 飞亚拓700e直升机 基本所有模式稳定 文件如下
    700e 参数2015.6.12上午.param
    6.BIN
    https://storage.ning.com/topology/rest/1.0/file/get/3702027197?profile=original
