Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • hi, is the a way to change IMU sampling frequency in AC3.3? for some reason I canoot find the old mpu6k frequency parameter. 3702079562?profile=original
      Artem,
      Yes, the MPU6K_FILT has been split and renamed to INS_ACCEL_FILTER and INS_GYRO_FILTER.  The way you use it is the same though.  I personally never adjust that parameter but my understanding is that smaller copters do well with a higher number to reduce the delay.
    Hi all,
    I added a discussion to sort out what we need to get Tri-Copters up to scratch. So if you have anything to contribute please go here:
    http://diydrones.com/forum/topics/calling-all-tri-copter-pilots
  • Hi guys,
    Sorry if this is slightly off topic.
    Just saw that the new Tarot T4-3D 3-axis gimbal is out.
    As it has an SBUS input I am wondering if the Pixhawk SBUS out port is fully implemented in copter 3.3.
    The wiki says it's not implemented yet, but there is a parameter BRD_SBUS_OUT, and I find out some info on the forums about it working, at least with ch1-8.
    The release notes also doesn't mention it.
    Thx,
    Igor
  • Here's some information.. (I think everything is working as it should)
    I just did an autotune of a little 250 size quad.  (3.3rc9)
    With the aggr set to .1, it tuned fine, but then after saving the parameters, and trying to fly again, it always flipped over when taking off.  My CG is a bit off, and the back is heavy, so that's why it's having trouble.  I re tuned the pitch with aggr set to .05, and now it works perfectly.
    FYI the CG is about a centimeter behind the center of the copter.
    • One more thing, I'm not sure if this is OK...
      I get "Bad AHRS" messages occasionally.  It seems random.  Just now, I've had the copter sitting on my table, and it was fine for the past 10 minutes, but now I'm getting the Bad AHRS message in MP.  (I haven't touched the copter at all).  It'll go away in a few minutes, and I'm sure it will return again sometime.
      Same goes when I'm in the field.  Seemingly randomly I'll get the Bad AHRS messages, then they go away and I can arm and fly w/out any  trouble.
        Scott, Shaun,
        I think we really need Dataflash logs from the event to know what's going on.  Probably best to turn on Logging-while-disarmed.
        • Been mapping solid for the last few days, so no logging lol.  Didn't even know you could turn logging on without arming.  Good to know.  Wondering though in the Bad AHRS is because the copter IS just sitting there.  Nothing for the accels to report, but the cheapo gyro is drifting.  Just a thought.
          • This reply was deleted.
            • Maybe a "checking parameters" or "testing sensors" message could come up until the EKF checks are completely. Then if there is a true fault, that fault could be displayed.
              Might help to reduce unnecessary worries about a false alarms.
