Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Is it possible that the Terminal (CLI) is not working since AC3.3?
    I would like to try AC3.3 but since rc5 (the first -rc I tryed) I got this:
    3702037709?profile=original
      Andre,
      It's disabled because you should be able to do everything you need (log downloads, compassmot, etc) using new MP features that use MAVLink instead.  If you really want to use the CLI there's a new parameter called CLI_ENABLE that can be set to "1".  The CLI itself has been cut down massively though so many featuers are gone from it.  We did this because it eats up developer and testing time to maintain multiple methods of doing the same thing.
      • T3
        Randy,
        is there any other tool available where one can easily select what should be logged? This was prefect with the CLI.
        • Welcome to the Linux mentality of software development. This is where the end user's experience is the bottom of the list of things to accomplish. It's just the nature of FOSS where things get done not because it's the right thing to do or will better the experience but because it is the pet project of the dev(s). We "like" to think all this stuff is for us, but it is not, it's for the devs. That said I am so glad that there are still devs willing to take their personal time to do any of this at all.
            Hi Craig,
            I am sure I can speak on behalf of all the devs when I say thank you for your kind words of appreciation.
          Thorsten,
          The latest mission planner shows individual check boxes for bitmask fields so it's much more convenient than before.
          3702790747?profile=original
          • well, actually this seems easier than the CLI. Maybe I should give it a try someday:)
            Thanks...
          • T3
            Randy,
            thanks! Perfect! I overlooked this because I am normally working with the full parameter list only.
        • I never tried but you should be able to download your logs through MP as Randy mentioned.
          I understand where you are coming from though. I am also so used to using CLI, I like to keep using it instead. One of the reasons why I am still with pre AC 3.2.1:)
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
