Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Welcome to the Linux mentality of software development. This is where the end user's experience is the bottom of the list of things to accomplish. It's just the nature of FOSS where things get done not because it's the right thing to do or will better the experience but because it is the pet project of the dev(s). We "like" to think all this stuff is for us, but it is not, it's for the devs. That said I am so glad that there are still devs willing to take their personal time to do any of this at all.
Hi Craig,
I am sure I can speak on behalf of all the devs when I say thank you for your kind words of appreciation.
Thorsten,
The latest mission planner shows individual check boxes for bitmask fields so it's much more convenient than before.
Thanks...
Randy,
thanks! Perfect! I overlooked this because I am normally working with the full parameter list only.
I never tried but you should be able to download your logs through MP as Randy mentioned.
I understand where you are coming from though. I am also so used to using CLI, I like to keep using it instead. One of the reasons why I am still with pre AC 3.2.1:)
Hi Alex,
I think Thorsten might be referring to the ability to specify exactly which logs are enabled. This was possible through the CLI in 3.2.1 using the command as below:
http://dev.ardupilot.com/wiki/mission-planner-terminal/using-the-co...
I installed rc7 today, knock on wood, the quadcopter has never been so stable. Even the wobbling on descents is improved. Switching from APC SF to MR may have contributed to that.
I normally do but not for this combination yet.
