Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
LifeStyle,
I think mission planner is always reporting the status of the first GPS on the HUD instead of the primary GPS. Ardupilot should report which GPS is primary so MP but it doesn't yet.
Hi Randy. Something related to this? In MP you can see the MagField for the compass being used by the FC. But what about the other one? Is there a way to read it? Maybe APM PLanner or Tower can show them?
I've been noticing something similar with -rc10 and the tower app. When I power up and connect tower will read NOFIX, then after the usual time it will annouce '3D lock', then I arm and take of and a minute or so later it will say "no 3d lock" even though it still has 12 sats and HDOP of 1.2 or less. The copter still flies ok in gps modes (Not great but it is never great... I have some tuning to do)
As far as I'm aware, it's because there's a new fix type of 4 which indicates a sbas fix. The old version of tower doesn't know this yet, so when your fix type goes from 3 to 4, tower says no 3d lock, but it will fly fine as the lock is better than a 3d lock.
Ahh great thanks Glenn and Randy, that will give me some more confidence when i'm in flight and my phone announces "Lost 3D Lock". :)
Yes, Glenn's right I think. I've raised an issue with the Tower guys here.
That’s some killer orientation skills when it knows where it is on a 4 dimension basis in a 3 dimensional world! 3.3’s getting better all the time! :]
I just had some thing weird happen with the Tower app ( not resently updated). I changed the mid throttle from 600 to 450 through the app, ( changed props from 13 to 15in) when I tried to take off I forgot to push the arm button on the quad, but attempted to arm from the controller.
I got the normal arming tone even though the motors did not arm. I am use to getting the arm failure tone when I make this mistake.
I pushed the arm button on the quad but got no conformation tone. The motors stopped pulsing and beeping so I armed the quad with the controller. In AltHld I raised the throttle above the dead band and the quad shot in to the air and I pulled the throttle to minimum and the quad stopped about 30ft up.
With throttle at minimum the quad was barely desending taking 2 mins to decend from 30ft. I had control of roll and pitch and yaw. Thankfully I got it back on the ground safely and disarmed normally.
The log from that flight would not download.
Get it from the SD card directly. Would be interesting to take a look at that.
If I remember correctly dev explained that they use overall health of the GPS coords which include GPS accelerations (can be mistaking here) but the error messages is still generic GPS fix for all GPS problems... M8Ns are usually the ones having such issues as they are waay too sensitive and pickup EM noise from the copter.
165
166
167
168
169
of 449 Next
