Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • T3
          Captain,
          hell of a lot of nuts around...
          I am pretty sure that AC3.3rc11 is not to blame if AC 3.2.1 is running fine. Your copter should fly better with AC3.3rc11
          But, have you gone through all the calibration steps again?
          Best regards,
          Thorsten
          • um no rc11 is to blame.. didnt do it on 3.2.1 the official release.. when i went back it was fine so it was the beta... dont forget im a captain and been flying helis for 20years now.. but this new tech is all software based.. to many sensors to many things to mess up.. before you had to actually know how to fly with this stuff its point and click..
              James,
              Where exactly do you think AC 3.2.1 came from, another planet perhaps? It came from the same developers working on this release.
              What Thorsten was asking you, which by the way you didn't answer, was if you had followed all the directions at the top of the page, you know the ones in bold red type warning you of impending doom if you don't do certain things like re-calibrate your accelerometers when upgrading from AC3.2.1? If you didn't then go back and follow the directions. I think you will find it makes a world of difference.
              Live long and prosper,
              Nathaniel ~KD2DEY
              • spock calibrated it for me... yes of course i did.. but for some reason it seemed like a drunk uncle that just got bad news that nascar isnt going to be around no more and his favorite beer is going outta business..
                but seriously once i went back to the stable release no problems...
      • ian,
        Make sure you are in the "Administrator" account when you do the MP upgrade. You may also need to turn off your virus checker when upgrading to the MP Beta release, others have problems with it. See this link: http://diydrones.com/forum/topics/mission-planner-for-windows-10?xg...
        • +1 on that advice - On Windows machines, always right-click and 'run as administrator' as well as suspend / disable any real-time virus scanning.
          • Thanks Phil, Kurt. Unfortunately that didn't fix it. I'm getting a 403 error from the server during the download of the dll.
  • I was wondering if this a new change that was meant to be there. In 3.2.1 using tower you could switch to Auto and without moving the throttle the copter would take off and fly its mission with out touching the R/C controller. I am trying 3.3RC11 and now in tower I switch to auto in Tower and I need to move the throttle to make the copter fly. Is this a setting I need to change or is this the way it is suppose to be for now?
    Thanks and Great work. Very smooth....
  • Not sure if this has been reported before, but setting either CONFIG_SONAR, CAMERA or AC_RALLY to DISABLED prevents Copter from building.  In the case of AC_RALLY that seems to be a simple typo, in case of CAMERA misplaced #ifdefs, but in the case of CONFIG_SONAR it seems like building without it is no longer supported?  I needed to touch up too many places to build without sonar.
  • I had a little incident today flying rc10. First off, The copter was in the trunk of my car all day and was a little warm when when it was initialized. The problem is I had had a radio fail-safe and it hit full throttle for ~ 1/2 sec and then dropped and revved up again. It hit 60 A witch is the max. Going from loiter to RTL, and once from RTL to loiter the throttle revved and then the copter jumped up then it sank back down(corrected the overshoot). I thought I just imagined it, I was flying fpv the first RTL. I watched the onboard video and confirmed that. I haven't changed any params, it must be something to do with a temp change after start up.
    2015-09-16 19-04-25.bin
