Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Tried Auto mission today with tower and could plan the mission but could not take off.  As soon as I touched the Auto takeoff button the copter switched to auto mode and shutdown.  It worked just fine using the transmitter.  This worked with the previous version of 3.3.
    I also think my Pixhawk is going bad as when I first plug it in I get bad AHRS.  If I unplug the unit and plug it back in it's fine.  It only does this the first time I use my IRIS.
    • I got that every now and then on rc-9 but do not seem to get it on rc10. Also after you unplug your lipo use a paper clip or something to short the leads on your connector to fully discharge your MR as some have said this solves the issue.
      • You might want to be careful about your wording when posting advice like this in case someone interprets it wrongly and explodes their battery :)
        • Any one who read those posts and thought they should short their battery as a pose to shorting the copter leads, likely should not be flying any thing more than a phantom any way.
          I do get your point though.
        • I understand what you are saying but I would think Darwin would sort that out pretty quickly :)
          But you're right. When I say short out the leads I mean the ones going to the copter/plane NOT the battery.
      • I get the bad AHRS message, bad gyro, and GPS health frequently on multiple firmwares.
        Unplugging the battery and shorting the leads seems to clear it up most times, other times I have to repeat the process as many as three times.
  • There are other issues on the flight but from what you told us, I believe this was the moment things began to act strange. Also to note, that the controller appears to have some brownouts, but I didn't look at this with care.
    3702885215?profile=original
    • Luis, are the brownouts that you are referring to the red spikes downwards?  I seem to have always seen these, so much that I thought maybe it is just a sensor glitch, they are never more than a sharp spike.
      Also, I know that other than the unexplained climbing and descending motion, the vehicle didn't got to full throttle and fly around like crazy for 2 or 3 seconds until the very end of the log. The last mode change was from stabile to alt-hold, and then when it touched down, all heck broke loose. I agree, it seems like a sudden displacement of the CG, like something falling off could have the vehicle reacting in this way.  It makes me wonder if it was the camera and gimble.  It will be hard to determine now, they were thrown from the wreckage..
      I'm pretty sure this is not a 3.3 issue now, so sorry I brought it up here.
      thanks for the help.
      RE
      • Don't know. It's always a case by case that has to be "traced" :) In this case it might be just a glitch because the other power parameters don't show anything:
        3702927912?profile=original
  • Sure, plain APM Planner 2.0.18
