Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
A false positive on the landing detector would be bad. Loosing GPS hold momentarily not so bad. Personally,I don't try to descent at minimum throttle but low throttle.
A minimum throttle GPS lock out would be great for me, maybe a check box to allow GPS lock so that those who want the feature could try and those that don't won't have to.
Using a range finder is a great idea also, would require every body to add another sensor to there machines- I would do it! I have a PX4flow sensor on the shelf that is just waiting to be played with.
Adding a minimum throttle GPS lock out option might even be worthy of summitting a formal feature request. Have to wait and see if any one else things it might be a good idea.
I think this would be bad for landing in windy scenarios when PosHold/Loiter is most useful. There would be the danger that the craft would suddenly get blown sideways when the GPS was ignored.
I wonder whether low-tech is best here. I have advocated ignoring yaw commands when throttle is at minimum in these modes so that you don't end up doing the disarm dance while the copter still thinks its flying. Why not instead of everyone switching to stab when they are on the ground have some "I've landed dance" so that the FC knows to basically shut down. e.g. if you are ignoring yaw at min throttle take full right yaw as "copter on the ground".
Yes I second
Aargh I absolutely hate this forum software. Seriously, was it designed in the 1980s? It randomly truncates replies to three words - usually the longer you spend composing the more likely it is to truncate. And why do we have a single thread with thousands of replies in a disorganised mess for such a wide topic? Why not have a separate area/forum for testing where we can have sensible threaded discussions about a single issue, like landing, or gps, or ekf, or autotune, etc etc that people can actually find, report, discuss, contribute to and come up with solutions for issues rather than each issue being lost and forgotten in the hundreds of pages of replies.
Anyway, I had composed an eloquent soliloquy on landing issues which I won't bore myself with again, but it boils down to:
- Cautious landing detector good, false positives and falling out of the sky bad.
- Landing detector not always great at detecting landing in good time, causing tipovers and mangled blades.
- An option to 'assist' or 'tell' the landing detector that the craft has actually landed would be a great addition, either using some wierd and wonderful three finger salute or by a channel switch.
- I use a popular tarot 650sport frame which by the time you add motors and batteries is top heavy and inherently unstable in landing, prone to tipping over (as are a lot of multicopters). Extending the landing feet/rods helps considerably, I actually use pool noodles/pipe insulators to wrap around the landing rods as I land on water sometimes. With the large landing feet and hence more stable craft I've never had a tipover and the landing detector seems to work much more reliably.
- Landing in an assisted mode (landing/althold/loiter) is safer for the vast majority of flyers, landing in stabilize should be a last resort/experts only. But landing in stabilize is the most reliable/safest from the moment it's actually touched down.
Fnoop, I fully agree with you on the software of this forum, there is a huge amount of very valuable information and help in some of the threads, but there is almost no way to find that information unless as you said you to scroll through hundreds of pages...
Agree about the software, if it only had thread tools, such as search within thread...
I also have the Tarot 650 sport and I never let the FC finish the land or RTL, I always switch to stabilize and land it by myself as it sometimes want's to tip over and I do fly mostly on difficult terrain (slope, near hills, forest and power lines near my LZ).
RC10 is much better then previous versions and far more stable on landings, but the landing detector still needs some improvements.
re- In a GPS controlled mode when the throttle is at minimum do not listen to GPS messages. Basically switch to AltHld mode when throttle is at minimum.
Wow... unless I'm missing something that seems like a fantastic idea and problem solver.
3.3 RC10
Really don't know what else the PixHawk wants to arm....
Screenshot from APM Planner via telemetry radio but the same thing happens if also connected via telemetry radio to Mission Planner. Both APM and MP latest beta version as of today.
Issue is that even with lots of satellites and 4 as GPS lock and small (<1.4) Hdop the pre-arm checks complain about 3DGPS Fix.
perhaps some candy ? :)
What kind of gps?
I ´ve got some weird indication with -rc10 and Droidplanner (1.2.0 first version)as well, it says NoGPS although HDOP and SAT count are great (M8N, no noise issues). Loiter works nice, as well as PosHold and the logs don´t reveal any problem. Rather a cosmetic issue. If your bird flies great, just de-activate those Pre arm Checks :-)
164
165
166
167
168
of 449 Next
