This is a discussion of getting the PX4Flow sensor working with Copter-3.3.1 (or higher).
Thanks, Paul. That sounds promising.
We intend to fuse the data from PX4Flow and our IR-LOCK system. In the simplest implementation, IR-LOCK would be used to correct the drift.
Also, we were thinking of using IR-LOCK to compute x-y velocities, but I am not 100% confident in that approach.
What exactly do you mean by "accurately focused and calibrated sensor"? Did you use the default 16mm lens?
Does anybody have experience with using optical flow at a much higher altitude, such as ~20m? ... My initial guess is that ~20m is probably not doable, but I would like to hear otherwise. :) We have some work that could benefit from it.
In case someone might find it useful, here's my notes on using the sonar on PX4FLOW as the analog rangefinder.
Since I mostly fly small quads indoors, I thought it would be nice to shed some weight by eliminating bulky and heavy LiDAR unit so I gave it a try, but it turns out my sonar unit was too noisy to be usable so I decided not to go this route, but your milage may vary.
Using the Sonar on PX4FLOW as RangeFinder
Connection
PX4FLOW supplies 5V to the sonar, so the maximum output voltage from pin 3 is going to be roughly 5V (slightly lower in practice). Note that this fluctuates depending on the quality of power source. When powered via USB, it's usually lower than 5v, but when powered via battery and power module, it goes over 5V.
Make sure you connect the analog out of the sonar to Pixhawk's 6.6V ADC input.
If in doubt, consult these pages.
Configuration
Testing
Hi Paul, I'm not sure why log shows like that and I've tested it indoor like space under big bridge which protected GPS signal perfectly. I'll do test it again. Thanks for your comment ^^
Hi!
I'm testing v3.3.2-RC2 using PIXHAWK and PX4FLOW.
I read reply Goro Senzai and all comments. But still have two questions
1) I’m set the EKF_GPS_TYPE parameter equal to 3 and trying take-off in Loiter mode. But copter lost PITCH control via transmitter and autopilot also cann’t control PITCH.
2) On the floor always "Error compass variance". I arm copter in hand and then put on the floor. I set FS_EKF_THRESH 0 (and second test set 1), but nothing changed.
Help me please with my questions. Thanks in advance
2015-11-25 17-14-18 26.bin
Interesting. It must've been fixing some other issue with my quad then. To be clear, it was the setting labeled "Loiter PID" in the upper right hand corner of Mission Planner's settings that appeared to "fix" my loiter issues. The settings labeled "Rate Loiter PID" did not resolve my issues.
Randy/Paul--
Under ideal Optical Flow conditions on a typical 450 class quadcopter (lots of incandescent light, varied ground texture, focused PX4flow, tuned PID settings, and altitude of ~1 meter) how much X-Y drift should we expect to see in Loiter Mode?
We're doing a project where we would like to follow LED beacons in a parking garage, so we're going to be pretty much between 1 and 2m altitude all the time.
Are there any plans to incorporate sonar backup for the lidar? If nobody is working on that yet, I could commit our changes? My idea would be to look at both sonar and lidar, then switch to sonar and reboot lidar if it becomes unstable.
Hi Fabien,
We are working on a somewhat similar project, but at a higher altitude. Let me know if I can shoot you a PM sometime. :)
-Thomas (IR-LOCK)
We're interested in developing a "next generation" optical flow sensor where the camera lens is slaved to a high accuracy laser altimeter in order to provide dynamic focus and increase the useable range. We're looking for someone to flight test our new SF11 laser altimeter with the PX4Flow so that we can collect some real world data before moving forward with the final design. @Fabien, would you be interested in testing the SF11 on your project? We already have some high altitude flight data but we need verification of the short range performance as well :).
