LabVIEW based ArduPilot Ground Control Station ( GCS) is ready for public beta test.
GCS wiki: See wiki for installation and configuration instructions (read through it, or at least watch video )
Requirements:
- Windows OS
- LabVIEW run time engine 9.0
- Google Earth ( if you already have it you don't have to re-install it. Google Earth version prior to 5.1 ( newest) should be fine)
- Ground Control Station application (zip file) - Updated May 16, 2010 !
New Features of ArduPilot GCS :Short introduction video explaining how to start and stop GCS:
http://vimeo.com/11772440
more comprehensive GCS video ( worth watching ! ) is here:
http://vimeo.com/11608873
- Data logging
- kml logging
- voice synthesis
- (UI has been redesigned, code architecture has been changed, etc.)
The GCS seems to start up ok, receives data, generates a data file and kml file which places the aircraft at the correct position. The hsi works but there are a couple of problems and I have a question:
1. The application does not close down when I press Stop and has to be removed using task manager. It will not then restart other than by restarting the pc.
2. The mode switch indicator works intermittently - it signalled Stabilise when I selected each position in turn and just stuck at that
Can it be used without GE connected to the internet using cached data?
Peter
ps I am using a Del laptop with win 7 64bit
not sure..can you post your kml file ( it's APflight_date_time.kml) and I'll take a peak
keep the test reports coming :)
Please have a look in the thread I've opened below:
http://diydrones.com/forum/topics/ardustation-pc-ground-station?xg_...
Thank you,
Leonardo
I do have two versions of Labview installed - 8.5(or maybe 8.6) for the standard AP software station and 9 for this GCS.
I have just been having problems with my Eagle Eyes on another aircraft and found I had to do a restart on the PC when I swapped USB devices so I will try again with the GCS after a restart.
Peter
data file includes only navigation and attitude data - in ArduPilot firmware those two sets of data are prefixed with !!! and +++ .
Hmm, multiple times I ran GCS and AP for almost an hour without a glitch... Based on all other things you mentioned, I think something else might be amiss .
As Chris mentioned, which AP version are you using? Was your AP battery properly charged ( I saw same thing you mentioned with flightswitch position only when my on-board battery was dangerously low , i.e. almost discharged )
1
2
3
4
5
of 7 Next
