BlimpDuino home page
3689304736?profile=original
BlimpDuino is a very low cost open source autonomous blimp. It consists of an Arduino-based blimp controller board with on-board infrared and ultrasonic sensors and an interface for an optional RC mode, a simple gondola with two vectoring (tilting) differential thrusters, and ground-based infrared beacon.
It is available as a commercial kit from the Maker Shed or the DIY Drones store for $89.
[UPDATE: The current Blimpduino kit has been discontinued. Stay tuned for a new design in 2012]
  • What else you'll need
  • Instructions for making the kit are here.
  • Instructions for loading the code are here
  • Correct LED/servo/motor behavior modes are here
  • Instructions for using Blimpduino are here
  • The parts list is here
  • The discussion forum for teams using Blimpduino in the FIRST Robotics aerial robotics demonstration is here
  • If you want to build your own board from scratch, the necessary files and component lists are here
  • If you want to print out a cool DIY Drones sticker like the blimp above has, here's a pdf.
3689304786?profile=original
The Blimpduino board is the core of the kit. Features:
* 17 grams, with ultrasonic and IR sensors.
* Controls two motors and one vectoring servo.
* Built-in RC compatibility (can read two RC channels--throttle and steering)
* Designed for a 7.4v LiPo battery; has an automatic power cut-off at low voltage to protect the battery.
Here's the board with the ultrasonic sensor removed, so you can see the Atmega168 processor underneath it:
3689304861?profile=original
Here is a video of BlimpDuino in flight, using a breadboard version of the controller board:
At the moment, we're using Pololu IR beacons as the ground beacon, but we'll eventually release our own, open source, versions of them, too.
Here's the board on the gondola with vectoring thrusters and the optional RC receiver:
3689304811?profile=original
The commercial kit consists of the following:
--BlimpDuino board, with all SMD parts already soldered on
--Other through-hole components, to be soldered by user (easy)
--A very simple laser-cut plastic platform for the board, battery, optional RC receiver, and motor components
--A servo, gears and motor shaft for the vectoring (thrust tilting) function
--Two motors and props
--One IR ground beacon
--52" mylar envelope
The following is a chronological list of posts describing the development of the project. This is mostly for those who want to follow along and learn about Arduino-based robotics. If you're interested in autonomous blimp development and want to know more about BlimpDuino features, they will give you some insight into the evolution of this project.
  • wo questions:
    1. The build instructions don't seem to address how to wire the power for the beacon. Is there another document with that info?
    2. The link "Instructions for using it are here" at the top of this page goes to the FIRST Robotics discussion page. Was this meant to be a link to a different page or document?
    Thanks!
    Yes, you can connect a Xbee module to the board via the FTDI port.
  • Hi everyone!
    I'm new to this kind of topic, my experiences in robotics are limited to Lego Mindstorms. So I was wondering, is it possible to equip your blimp with XBee so that it could be controlled from a computer? Especially your final version that I could purchase from http://www.makershed.com/
    Thanks for your help!
    Robert
    Absolutely. It would be easy to add a magnetometer.
  • @Chris. Hmmm, I think that a magnetometer in this case would make a lot of difference, I have a feeling there's a spare input left on the board after the shield has been attached. Maybe that's a future project... Thanks.
    Matt: You could certainly try. Autpilots that use GPS to get a directional vector require forward motion to work (so the blimp would have to be moving) and the navigation algorithms were not designed for the kinetic latency that charecterizes blimps. But the code could probably be tweaked to do an okay job.
  • Congratulations on making it in the MakerShed! I am pre-ordering this weekend!
  • Hi Chris,
    I have a 20' blimp that was originally designed for indoor use and used brushed motors back in 2001.
    If I retrofitted it with brushless and rudder/elevator, would I use ArduPilot to control it? I would only fly it in winds under 10kts. It has full thrust vectoring.
    thanks
    Cool! I like the ultrasounic beacons and Xbee wireless. Too heavy for our much smaller blimps, but a good idea all the same.
  • Hi,
    I thought you guys might like the Penguin Blimp seen here (Festo Vid):
    https://www.youtube.com/watch?v=E8B4_fGopzw
    May be using your tech!
    See the close-up at 1:39
    Matt
