BlimpDuino home page
3689304736?profile=original
BlimpDuino is a very low cost open source autonomous blimp. It consists of an Arduino-based blimp controller board with on-board infrared and ultrasonic sensors and an interface for an optional RC mode, a simple gondola with two vectoring (tilting) differential thrusters, and ground-based infrared beacon.
It is available as a commercial kit from the Maker Shed or the DIY Drones store for $89.
[UPDATE: The current Blimpduino kit has been discontinued. Stay tuned for a new design in 2012]
  • What else you'll need
  • Instructions for making the kit are here.
  • Instructions for loading the code are here
  • Correct LED/servo/motor behavior modes are here
  • Instructions for using Blimpduino are here
  • The parts list is here
  • The discussion forum for teams using Blimpduino in the FIRST Robotics aerial robotics demonstration is here
  • If you want to build your own board from scratch, the necessary files and component lists are here
  • If you want to print out a cool DIY Drones sticker like the blimp above has, here's a pdf.
3689304786?profile=original
The Blimpduino board is the core of the kit. Features:
* 17 grams, with ultrasonic and IR sensors.
* Controls two motors and one vectoring servo.
* Built-in RC compatibility (can read two RC channels--throttle and steering)
* Designed for a 7.4v LiPo battery; has an automatic power cut-off at low voltage to protect the battery.
Here's the board with the ultrasonic sensor removed, so you can see the Atmega168 processor underneath it:
3689304861?profile=original
Here is a video of BlimpDuino in flight, using a breadboard version of the controller board:
At the moment, we're using Pololu IR beacons as the ground beacon, but we'll eventually release our own, open source, versions of them, too.
Here's the board on the gondola with vectoring thrusters and the optional RC receiver:
3689304811?profile=original
The commercial kit consists of the following:
--BlimpDuino board, with all SMD parts already soldered on
--Other through-hole components, to be soldered by user (easy)
--A very simple laser-cut plastic platform for the board, battery, optional RC receiver, and motor components
--A servo, gears and motor shaft for the vectoring (thrust tilting) function
--Two motors and props
--One IR ground beacon
--52" mylar envelope
The following is a chronological list of posts describing the development of the project. This is mostly for those who want to follow along and learn about Arduino-based robotics. If you're interested in autonomous blimp development and want to know more about BlimpDuino features, they will give you some insight into the evolution of this project.
    Wes, Blimpduino 1.0 has been discontinued and we have not finished a design for Blimpduino 2.0 yet. I think it will be early next year. More time = better, cheaper sensors and a more powerful board.
  • Can I ask what the flaws were with the last design. Was is just the age of the components? I'm currently trying to piece together a BlimpDuino from individual parts. This IS possible, right? I can use the parts lists and code linked above and built it myself?
    No ETA yet. It's an interest of mine, too, but I think we want to redesign it from scratch to use the latest technologies. I'll probably turn to it before the end of the year, but if community members want to come up with their own design that we could produce, that might speed it up.
  • We are almost mid year, any news on the new Blimp
  • Any idea on when the new release will be, and is there a changelog? I'm about to use Blimpduino to start work on a master's thesis and I want to have the most recent stuff.
  • please... is there any news about the new coming Blimp ??
    I'm waiting....!
  • I just wanted to post saying that after a little over 5 months missing, FaceBlimp was returned! See http://fryfrog.com/2011/01/12/faceblimp-found for the full story.
  • Anyway to build it that will enable outdoor flight with a gopro hd (90 Grams)?
  • Seems promising! Please let us know when you have a date for the launch!
  • Awesome, I'll be waiting!
