Copter-GCS: Android ground station for ArduCopter
GPSSample.png?width=420Hello all,
After some field testing, i'm finally ready to release a copy of the Android based, bluetooth GCS for ArduCopter into the wild.
For all the details go to the site.
Its available in 3 ways:
  • Install from Android Market ($5, largely to offset publishing costs/support development) Copter-GCS
  • Install the APK from the download section (Free)
  • Build from source, following these instuctions.
The reason for the market version is for those who would like to just install in the easiest way possible / receive automatic updates or would like to support development costs (thanks you) such as the fee required to publish on the market.
connected.png?width=200gpsModeStatus.png?width=200offsets.png?width=200
Current features:
  • GPS plotting of phone and GPS, quad path rendering and logging of the track to the SD card.
  • Sensor graphing
  • Status display, such as current mode and GPS state
  • Setup
    • PID Tuning
    • Accelerometer Offsets, both traditional and using the drift direction
    • Transmitter Calibration
Let me know how it works for those that try :)
Bart.
  • good to know! thanks!
  • It should work. I've tried 2,4Ghz and 900 Mhz with no problem.
    But not with APM.
  • great! Have anyone done the BT bridge  to 433MHZ RF yet to talk with APM yet?
    In my thought, it should be just to connect to TTL level TX/RX of BT module to 433MHZ RF RX/TX pin.
    anything missing?
    thanks
  • Ah, now I get a hearbeat but still no data.
    bds is at 57600, same as xbee.
  • Any news on the development?
    I'm using android 4.1.1. , can connect to bluetooth and bridges appears but then I can't get any data.
  • if you can't update, then the only solution is to build it yourself from source, using proper Android SDK.
  • now that's seriously old Android.
    Luckily you can, run at least ICS on it: https://www.youtube.com/watch?v=ezSWg2dLPFA
    So just update.
  • @luca
    I have much of the USB stack working on copter-GCS, but cannot do that last (small) bit without a tablet and some debugging.
    Work is nuts, but at some point (months), once I buy a tablet, I can tie in the USB. All my projects have been frozen for some time now.
    Sorry,
    Bart
  • mee too, it'a pity that Michael's Mission Planner is made using .net and not QT.  - then it would be very easy to compile it for Android.
  • Who's using MAVLink 1.0 ? - APM planner + default firmware uses 0.9 ?
