I get this question all the time: what's a good plane to turn into a UAV? The answer is that it depends on your needs, your budget and your RC skills. But here are some good electric candidates:
For RC beginners:
The NextStar (see above) is roomy, slow-flying and comes with everything you need (including a RC flight simulator). It even has its own rudimentary flight-stabilization system with a Futaba PA-2 optical co-pilot.
For DIY'ers on a budget:
The $110 SuperStar is a nice-flying four-channel plane with enough room for an autopilot and cameras strapped below. The ARF kit comes with a brushed motor and NiCad batteries, which are enough to get you started. When you're ready, you can upgrade to a brushless motor and LiPos. This is the plane we use for GeoCrawler 2 and will also be the basic platform for our ArduPilot-based UAV. You can hand launch it in a park, or take it off from a runway at an airfield. It's tough and can handle wind. All and all, a really comfortable plane to work with, especially once you upgrade the motor and battery.
[Note. This plane appears to be discontinued. You might want to check out the NexSTAR Mini EP as a replacement. It's not quite as good, as it's more expensive and has less interior room, but it does the trick]
For those looking for long flight times:
The Aero-Master is a powered glider with a pusher prop, which means no propellers in the way of your cameras. This is the aircraft used by Marcus UAV.
For those who want to carry heavy, high-resolution cameras, with unobstructed views:
[This one appears to no longer be available, although a larger gas-powered one still is]
For an all-around great first UAV platform:
EasyStar. The classic. Easy to fly, hard to break and plenty of room for electronics. Works best with a brushless motor upgrade.
An even cheaper variation on this, with the helpful addition of ailerons, is the Dynam HawkSky. Well worth considering as an EasyStar alternative,.
And this is my latest addition to my hobby UAV's - A Mountain Models Tyro 150, 55" wingspan, 600 sqin winga area and only 42 oz with a 3S-4270 LIPO pack (40 min runtime).
Interesting list! I would add a motor-glider type airframe if you are going to use an off-the-shelf solution like the Picopilot. I have tried a lot of different airframes and if you want a quick route into testing autonomous flight, a Picopilot -NA and a Miss2 is the way to go...The SIG LT-25 is available as an ARTF now and looks very suitable, even for the Picpolpilot if you use a mixer for ailerons/rudder.
-dave
-dave
Thanks for the reminder of the popularity of the SIG Kadet for UAVs. I should have mentioned in my intro that I was just covering electrics, which we prefer for most purposes for the usual reasons (noise, safety, reliability, lack of mess, etc). But the gas-powered Kadet is great for heavier payloads and longer missions.
I plan on using a Sig LT-25. Just about the right size for my motor, but the fact that its a tail dragger is going to make calibrating the gyros on start up harder.
Anyone have experience with the LT-25 in terms of a UAV?
There are some design/build issues with the 81" Skymaster (things like the wing tubes, and no riudder)
I haven't found the right powerplant for the Skymaster yet, but I'm sure it'll be some honkin' big brushless. (there's enough room for a car battery, so amps ain't gonna be a problem!)
Chris is right on with this list.
1
2
3
4
of 4 Next
