2nd test with the gimbal: 2 axis, pitch and roll stabilized by a homemade mechanical gyroscope. Using a GoPro
In this second test, I added another joint so it can move freely in 2 axis as seen in the beginning of the vídeo. The performance was nice although i performed some very aggressive movements.
PS: i didn't use any bearing in joints, it's just a bolt, that's why the vídeo has some vibration. When I correct CG and replace bolts for bearings the performance will improve
Thanks Daniel. It seems that 2 gyros in opposite directions cancel the stabilization, take a look:
https://www.youtube.com/watch?v=bzbVwiIeM0M
Thanks guys ;)
Gary, i'm curious about trying that too hhehe
Guto, in the first test the gimbal could move only in the pitch axis. Now I'm using pitch + roll. It's my lucky shirt hhauh
John, i still haven't measured accurately but it's less than 5A
avionics, that's for sure hhauha
Neill, it's a 2200 kv motor
What are you using as a rotor?
Looks like a dt750?
I am sure you got sea sick when testing your gyro ! :-)
@Bernardo, great mechanism concept!
very instructive and fun...
Looks like a better test than last one, did you change anything?
By the way, wonderful shirt!!!!
I think you've really got something Bernardo, It will be really interesting to see how this performs in a multicopter.
