Chad Amonn, one of our mechanical engineers, has been busy designing some new products. He created this package to hold electronics designed by: Craig Elder, Sam Kelley, Kevin Bretney, and Jeff Wurzbach.
Any ideas on what this thing does?
(Edit)
MAV Station is part of MAVelous
What is MAVelous?
MAVelous is a browser based Ground Control Station that John Wiseman, Pat Hickey, and now Kevin Hester have been working on. It is an alternative to Mission Planner or Droid Planner, QGC etc. In order for MAVelous to function you need a server that converts MAVlink messages into HTML. MAVStation is that server in a box. It is small enough you can easily carry it around and take to the field with you.
Basically you have a radio and MAVLink between the vehicle and the MAVStation, and Wi-Fi link between the MAVstation and a tablet.
Inside the MAVStation is a Raspberry Pi computer running the server, plus a rechargeable battery to power it. There is a Wi-Fi connection allowing you to connect to a tablet running a browser. You also get a GPS and a 3DR radio to connect to the vehicle. There is a charger that runs off of a USB connection or an external power supply and there are also servo outputs available to steer an antenna tracker.
But wait, there's more....By the time you have all of those elements in place, you only need to add a handful of additional buttons and you now have a box that can be used as a Follow Me device.
In the best of all worlds, the Follow Me device would be optimized and made smaller and easier to carry around, but this is a great development platform and a great place to start.
Hmm dvr actually makes sense!
DVR
+1 on Follow Me box.
-=Doug
My guess is a follow me box as I think its a Ublox GPS and telem radio/ but with some sort of GCS as I dont see what else the RPI would be used for? And where does battery go?
Looks cool! Must be able to act as a follow-me box, but what's the composite video for ?
I don't see in-out so it can't be ground osd.
@b nevins: The composite is a output and the SD card is the computers "harddisk".
APM V3, based on RbPI.
1
2
3
of 3 Next
