I am pleased to inform that UgCS 2.1 is out now. All versions including UgCS One are available.
There is of course UgCS Open which is free and will suit needs of most of hobby users who fly drones for fun.
With UgCS version 2.0 one has ability to search for locations via text search and our new 3D map engine supports different sources of maps. Custom map sources can be added in configuration tab of the software.
We have retained multi drone support even for Open version thus you can work with scenarios involving multiple vehicles.
UgCS runs on MacOS/Linux/Windows and supports most of popular autopilots such as 3DR AMP/Pixhawk, DJI Naza(Phantom2)/Wookong-M/A2, ARDrone, Mikrokopter
Here is full list of changes from 2.0 to 2.1 http://ugcs.com/release-notes
Thank you,
UgCS Team
Alexei, you say you have support for H.264 network streams. So far we have been unable to get a Wi-Fi based stream using UDP/IP RTP container using H.264 codec to work at all without having to transcode the video MJPEG which is a very slow process and makes it almost unusable. Can you provide specific instructions on how we can make this work with minimum latency. We are using gstreamer currently.
Fnoop Dogg, yes, thank you, detected the issue. I'll post a comment when we'll fix it.
Dan, yes we do support h.264. In general we can work with network streams and streams from devices connected to USB. If you experience any problems with video please tell us you video encoder type.
Doesn't support latest ubuntu unfortunately so I can't test it. Looks good though from the screenshots!
You can setup your own map sources or use ones you have bought commercially. Locally hosted Geo map server is also an option.
Our map engine caches maps by default. Cache is limited by size, default is 1GB. It can be changed in map.xml parameters file.
Here is screen from options to set up map sources:
