Dear All,
As I announced on this forum we are aiming to build a man carrying drone; it is a multicopter. we have made quite some progress. Have a look:
www.thehummingmanproject.com/blog
best regards Winfried
Dear All,
At the risk of being labeled a "hater", I feel I should elaborate on my previous post. I believe that a craft of that size with fixed rotors will be difficult to control. Making the props as light as possible will help mitigate the inertial delays on your control inputs, but using variable pitch rotors would be much more controllable. On a positive note, your power seems good enough for about a 600lb (272kg) TOW, depending on how efficient the powertrain/rotor combo is.
I tip my hat to the ambitiousness of your project. I just hope you (and everyone really) proceeds with the highest amount of caution. I just don't want to see anyone get hurt.
dear Hans, Quite fun that you take the same analogue thinking: indeed the Sikorsky price contender that may be a 1 kW available, And we all know the relation lower differential airspeed makes more efficiency. Our compact design indeed needs some more power ca 6 x 6.5 kW. best Winfried More compact again would require more!
Nice Tommy, it is quite similar to the kick starter project or is it that one?
Best Winfried Are you still in this area?
Of course Tobias we know the evolo and the guy starting it. The size of that one is a little too big in our view; we would like to get it to 2.5 by 4 meters. But indeed we used their lessons.. best Winfried
Agreed.
This community is for sharing and supporting our fellow hobbyists...it's sad how quick the haters pop up everywhere these days.
Surprised at the amount of negativity here, the "it's been done", "won't work", "bad design", etc ...
If the Wright Brothers or other aviation pioneers had listened to these kind of comments (and I am sure there were plenty), we would not have any heavier than air machines flying today. And in more modern times no ipod or smartphones if Steve Jobs had listened to the kind of negative reactions and sneers he got when introducing said ipod.
Par for the course, I suppose ..
You go, Winfried!
Sorry to spoil the fun. These people already advanced their human multicopter quite lot: http://www.e-volo.com/
https://www.youtube.com/watch?v=L75ESD9PBOw
https://www.youtube.com/watch?v=6rK2Url7UBQ
I made these drawings some time ago... :)
http://diydrones.com/profiles/blogs/full-size-y6-air-scooter
Looking at Hobbykings contest to lift beer, several managed to lift 50kg+. With more engines it should not be a problem. Doing this "effective" is a completely different thing.
My own little drone needs 130Watt for lifting 1kg with 4x 10" propellers.
It's pretty good with 7gram per Watt.
Atlas Human-Powered Helicopter - AHS Sikorsky Prize, where a pro cyclist generate 650Watt to lift 80kg + 4x 20,2m propellers.
Total incredible with 125grams per Watt
BTW, have you test with a scale model? Having a heavy keel under a drone is not always a good idea. It may be better to carry the pilot hanging in a joint coupling.
https://www.youtube.com/watch?v=syJq10EQkog
