Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode. You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude. This bug will be fixed in AC-3.0.2.
- Inertial Navigation for Loiter and Auto meaning much more accurate control (Randy,Leonard,JonathanC)
- 3D navigation controller follows straight lines in all dimensions between waypoints (Leonard,Randy)
- "compassmot" to compensate for interference on compass from the pdb, motors, ESCs and battery. (Randy,JonathanC) (Set-up video here)
- Safety improvements:
- simple Tin Can shaped Geo Fence
- pre-arm checks to ensure all calibration has been performed before arming (can be disabled by setting ARMING_CHECK to zero). (video description here)
- GPS failsafe - switches to LAND if GPS is lost for 5 seconds
- stability patch improvements to stop rapid climbs in very overpowered or overtuned copters
- Circle mode improvements including "panorama" when CIRCLE_RADIUS set to zero (Randy,Leonard)
- SONAR_GAIN parameter added to allow better tuning of sonar surface tracking
- CH8 auxiliary switch (same features as CH7)
- works on PX4 (some minor features still not available) (Tridge,PatH)
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen. The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults. The modified PID values for the 3DR frame can be seen in the image below.
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to Marco, DaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period. Some of their videos can be found here, here, here, here, here and here. Thanks also to MichaelO for the MP changes required for this release.
All feedback welcome. Please put your questions, comments (good and bad!) below.
Hi.
I have the same issue as Giuseppe but not so agressive. I test at higher altitude (i think it's a must)
When I engaged loiter the copter drifts inmediately. I've reduced "loiter P" a bit.
I have an external compass and I've done compasmot with 6% result. Accel noise (x,y,z) is very low as you can see in log.
I've tested the same hardware configuration, same GPS, APM 2.5 but internal mag and loiter was working well (only a bit of toiletbowling).
GPS Hdop was 1.6 with 10 sats.
I need help with this issue. I've not any brilliant idea. ¿Maybe Hdop? ¿Compass calibration (i've done live calibration)?
over 4910 - Loiter
4924 - Fly away
5149 - return to stabilize
PD: AltHold + simple mode works perfect
2013-08-18 22-05 3.log
Hi folks
I noticed that the vcc monitoring with the 3dr power module is not very stable and approx 1v to high (3s) .
There is no manual volt adjustment tool anymore, so I reduced the voltage divider to 9 and now it's almost perfect at 12.6 for a full battery. Is this the correct solution or is there another parameter?
I'm quite sure that this problem had been discussed but I couldn't find it anywhere.
thanks
andreas
i need you help..
i just to check my compass offset values
all is good but not my x value which is -213..i have an external compass and only 7% on compassmot
my quad flyhing very well without problem so what could be causes this problem with my x offsset?
i have made my compas calibration outside with no mettalic things near of my pcb board(all my screw are made in nylon)
does it a problem with missionplanner
How can I set the maximum angle the copter will tip when it's flying in auto mode? Is there a parameter for this?
Randy. May you help me?
I installed the external compass. Now motor interference is down from 130% to 13% only. Loiter is not trying to flip the ufo anymore. Woot! But a new problem is born. After external compass z offset is over 400. Y and X are good (around 30) Any ideas? Gps antenna is attached to the frame and external compass is up 10cm over a stand. Could this be the problem?
Thanks in advance Randy
Posting this question after spending more than an hour searching elsewhere for an answer, I hope someone can help.
I installed Arducopter 3.0.1 on an APM 1.4 (2560) board successfully and did initial setup just fine (frame, compass, accel). When I get to Radio Calibration however I can't go further, I get incorrect input results even though the radio connections are correct. Have tried using the terminal too, with no success. I also tried re-binding the radio and receiver, and double-checked the switch setup in the radio.
This is definitely a firmware issue because it was working fine with the previous firmware.
Can anyone help? Why would an APM1 give garbage radio calibration with this firmware?
Radio: Spektrum DX8, receiver: AR6200
Help guys! I want upload the 3.0.1 firmware to my APM2.5, but I can't update my Mission Planner. The only newer version of MP that works in my PC is 1.2.50, after that version any update I make, the MP crashes on start.
I have .net frame 4.5 installed on win7, and directx updated.
Any Ideias?
I can't seem to converty my tlog to kml is anyone else having this difficulty?
Steve
After waiting 6 weeks for my external magnetometer to arrive due to a shipping mess up, I installed it about 17cm above my quadcopter frame with the chip on the mag at an identical orientation to the chip on the APM2.5, declination entered manually at -17.3, auto declination disabled, re-did the compass calibration/dance, did compassmot and got 1% interference (from 35% before). Great stuff, I thought and took it out for a test fly.
After waiting until I had 10 sats I took off and flew a bit, then went to ALT_HOLD, all fine, then into LOITER... the huge smile that was about to split my face just evaporated as my quad went into a graceful 4m radius toiletbowling loiter! I was gutted! Everything I've read has led me to believe that this ext mag is supposed to solve the toiletbowling problem completely.
So I then reset the APM and did the entire setup from scratch, out again and it was better but after yawing the quad started to toiletbowl again, but at least it doesn't happen with every Loiter but I never know when it will loiter correctly or start toiletbowling.
Annoyed and disappointed are two understatements!
Big thanks to the dev. team and to Randy for his advice to change my setup for something more powerfull. I'm now flying 4S, and with my 9x5x3 propellers, I don't have any vibrations anymore. So I manage to fly 60km/h at 2m or less above the ground, so wonderfull !
For me with all the feature of 3.0.1 code, it's better than DJI Naza, juste amazing !
To be even more better, it could also be nice to have those features (including correction of GPS glitch) :
- More reaction in Alt Hold, when throttle stick is outside deadband, and lower deadband.
- Less sensitivity of vibration like DJI Naza does (could also be corrected with good propeller)
- Simple tuning configuration like Naza assistant (only percent value for simple parameter like Alt Hold, Attitude, Reaction to user stick input in Roll / Pitch / Yaw, ...)
- After selecting a tuning parameter, min / max set automaticaly (for exemple : 2 time current value for max, half for min value)
But at this point it's really really wonderfull ! Thanks again.
27
28
29
30
31
of 42 Next
