Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Randy, did this get put into rc6?
You guys are awesome! Coming to arducopter from other platforms was worrying at first - you always wonder what features will be different, but I'm very impressed with how thorough you guys are in both design and resolving issues and implementing new suggestions and features. This project fills me with a sense of excitement! A definite pat on the back to all involved.
Is anyone having problems with Teensie working on their Taranis/X8R/X6R on 3.3? I just set it up, but there is no data feed on the Teensie. It is only blinking about once per second.
I bought it here http://www.droneshop.biz/radio-gear/telemetry/taranis-mavlink-apm-p... and believe set it up correctly.
Thanks.
what firmware do you use on your Teensy?
APM MavLink to FrSky X8R S.Port converter
MavLink_FrSkySPort
https://github.com/wolkstein/MavLink_FrSkySPort/tree/s-c-l-v-rc/Mav...
Try these values for your SR2 parameters:
(assuming you are using Telemetry 2 port for the Teensy.)
I posted discussion on this issue here: http://diydrones.com/forum/topics/amp-to-frsky-x8r-sport-converter?...
Serial 2 protocol needs to be set to 1 for mavlink. Teensy needs Mavlink data streams on input side.
I started having some reliability problem with the same since 3.3 throughout rc2-rc5. Re-flashed tensy/taranis and fine-tuned params and it is ok again. Some further discussions are here.
Tensy led messages are the following: (no of blinks)
1 - No MAVLink data
2 - No Telemetry packets
3 - Missing SYS_STATUS data
4 - Missing GPS data
5 - Missing VFR_HUD data
6 - Missing RAW_IMU data
7 - Missing ATTITUDE data
I believe only protocol Mavlink (1) will work - however SRx params needs to be set.
Hi, I have my Teensie on Pixhawk at Telem 1 without any problems. I miss only the dates of hdop, all the other dates comes correctly.
Wow somebody is making a killing on these lol nearly double the price of buying a 20 dollar Teensy and a few wires but anyway. You may have to enable the Telemetry on Serial 2 in advanced or tree view in mission planner.
You may also need to click the button under "OSD" to enable telemetry to stream even if not detected.
Ah, well, there is a bit of code included. I don't care to spend hours constantly modifying lines of code when someone else did the work, "did" work well and looks good. If Droneshop wishes to continue selling their product, they need to support it. Peter King is a decent guy.
Thanks for the info.
