A big code release tonight--this is the full setup that won the Sparkfun autonomous vehicle competition. Along with general improvements to the code, this is the entire package of autopilot, setup utility and ground station code. It's a full Unmanned Aerial System, not just a UAV! ArduPilot 2.1
  • All the features of ArduPilot 2.0 plus...
  • Supports XY sensor in diagonal postion
  • Requires Z sensor [UPDATE: FMA is no longer carrying those. While we sort out alternative sources, you can buy them from Dean Goedde for $40 (scroll down for price list)
  • Controls throttle if airspeed sensor is attached via the ArduPilot expansion board.
  • Supports desktop setup utility for waypoints and autopilot settings. (Waypoints are no longer manually entered in the code. They can only be entered with this utility.)
  • Last version of the code to support the original ATMega168-based board. Future versions will require the new ATMega328-based board.
  • Field setup procedures are here
  • Get it here
If you are using the expansion board and airspeed sensor, to control the throttle you must solder a wire from digital pin 8 to "MUX IN 3" Desktop setup utility
  • Add waypoints manually; utility displays them on Google Maps
  • Set max altitude, speed, circle radius
  • Set elevator, aileron/rudder trim
  • More features coming
  • Get it here ("ArduPilotConfigUtility")
When using this utility for the first time with ArduPilot, click Write before anything else in order to format the EEPROM. Also, ensure that the "Set RTS on close" box is checked in your serial port's advanced properties (control panel/device manager), as described in our Arduino debugging tips) Ground station
  • Requires free Labview runtime engine and serial drivers (install both. Note: if you've already installed Lego's Mindstorms NXT software you may find you've got a driver conflict, because it's based on LabView, too. Uninstall the Mindstorms software first.)
  • Works with Xbee wireless modules
  • Displays real-time attitude, speed, altitude, current waypoint, heading, distance to next waypoint, etc
  • Displays real time position on Google Earth
  • Get it here
  • Source code is here
    For the 3rd time in this thread: "After uploading waypoints to the AP board with Arduino and then running the ArduPilot Config Tool, selecting the right com port and selecting read, it reads but no waypoints show up in the main window?
    Shouldn't it show the waypoints currently in the AP so that one can edit them?"
    Could you please explain "doesn't work"? We need more info to debug.
    Sorry, Ardu Utility doesn't work
    Also no waypoints in Waypoint tab of latest v2.1, copying waypoints over from v2.0.1 & compiling gives error: ... not declared in this scope.???
  • Jordi, I'm using the 1st release ardupilot board date : 11-17-08 and second release board with atmega168. I don't think my FTDI cable is bad, because I have try the confing. tool with the second board with the same FTDI cable and I can add waypoint and write to its. Any clue?
    Yes, it's here.
  • Thats better, makes much more sense now. Version on the Google Repository is correct.
    Thanks for quick response.
    @HappyDude: I reuploaded. Check again, please.
    Take a look at todays announcement by Jordi about adding more sensors .
  • This looks a fantastic system. I'm just wondering is there any way to be able to get it to display battery voltage or did I miss something?
  • I hope I am not missing something obvious, but when I download the Ardupilot2.1.zip the code appears to be the same as 2.0.1??
    I had a quick look through the code as I thought just the software version might not be updated, but there doesn't appear to be any support for diagonal sensor or throttle control.
    Could somebody please check the 2.1 code from the Google Repository to see if they have the same problem?
