What airframes are you flying with APM?
Here's what I'm flying with ArduPilotMega:
--EasyStar (default settings work fine)
3689379871?profile=original
--SuperStar EP (default settings work fine):
3689379917?profile=original
--Skyfun (default settings work fine)
3689379952?profile=original
--Skywalker (picture at top)
--And of course ArduCopter!
What airframes have you flown APM with? Any tips or changes needed?
  • Hi Ron,
    What is the status of the A380... did it fly yet?
  • Reichard Proxima II electric glider
    I finally managed to fly with APM on Sunday. Here are some photos and a video of loitering. Well, it was flying a pattern which first looked like a figure 8 and then the olympic rings. Any idea why? Will check everything again and fly a real mission when I can.
    Preliminary conclusions: Manual mode is good, stabilize is very convincing, FBWA and FBWB work, loitering must be checked. PID parameters appear to be reasonable, no sudden movements.
    It was awesome to have the model fly with me hands off for the first time!
    3689393108?profile=original3689393096?profile=original3692180030?profile=original
    3692180009?profile=original
    The setup:
    Reichard Proxima II glider, 2,78 m wingspan.
    HS82MG AIL and FLAPS, HS65HB ELE and 9g cheap servo for RUD.
    Dymond AL3548 outrunner 630 watt, 900 Upm/V and 60A Dymond regulator.
    11,1 V 3300mAh LiPo battery
    13" x 6,5" folding propeller
    Radio:
    Futaba T8FG with RH6008HS RX
    Ch1: AIL with Y-cable
    Ch3: Motor
    Ch4: ELE
    Ch5: RUD
    Ch6: Flight mode control
    Ch7 and Ch8: Flaps, not connected to APM but directly to the RX.
    APM:
    APM, IMU, Mediatek GPS MT3329, XBee 900MHz wire. Powered by a separate 1000mAh LiPo at 7,4 V (solder jumper removed).
    Portable PC ASUS Eee 1000H with XBee 900MHz&duck antenna and HappyKillmore's GCS (that I can't look at when I'm flying anyway).
    FlycamOneIII
    Next improvements to be done are:
    Connect the airspeed sensor.
    Find a better way to mount the APM and associates under the hood whilst maintaining access to buttons, connectors and view of LEDs (transparent hood, holes).
    Sort out the chaos of servo-cables in the fuselage.
    Variometer based on a high precision pressure sensor, I2C/SPI.
    Other issues:
    Flaps are controlled manually on two separate channels to slow down for landing. It would have been nice to have differential ailerons, but I understand it's a matter of priorities. None of the other mixes (e.g. butterfly) will work because of the y-cable so we might as well accept to live without them in the APM domain, for the time being.
    The model is quite beaten up, it has 55 hours of flying on it and a few crashes too. A brand new copy sits in the basement and will be used to build a perfect Proxima with APM when all tests and trials are completed. I will come back to you to discuss particular technical issues in the appropriate sections of the forum.
    Cheers from
    Parapendioper, Italy.
    https://storage.ning.com/topology/rest/1.0/file/get/3692180009?profile=original
  • Just thought I'd add to this. Some great aircraft being put together, the shark looks as thou it'll fly for days!! Great job.
    I'm flight testing in a Skywalker, although wasting heaps of time tuning the HIL on the sim only to find out it means diddly squat in the feild, very frustrating. The project result will be a PC only controlled (USB - PPM - UHF LRS) 80" Cub tasked with FPV/AP. Long slow road but............stupid working for a living.......
    Congrats to the team on the APM 1.0 release as well as the guys producing the GCS software, really great results, thanks.
    George.
    3692140973?profile=original
  • This is what I've been using. It's a 36" Scratch wing built out of 1/2 insulating foam.  So far it's been flying great with the APM and IMU.
    http://www.rcgroups.com/forums/showthread.php?t=1346340
  • F-27 Stryker. Still need to fly it, but default settings (eg Skyfun) look like they'll work ok (replaced a FY-20A with Ardupilot Mega)
  • @ManuelViriatoRamosVeloso
    Very nice work. Look forward to seeing it fly.
  • Thank you Ron.
    The fuselage is the part did not come from the shelf.
    It was design and made by me. Pure homemade piece.
    MVel
    shelf.it
    This domain may be for sale!
    Where did your fuselage come from? Is it purchased or scratch built. Nice.
  • My bird is a fish.
    This is my flying shark.
    This is almost on off the shelf plane.
    The fuselage are made of carbon and kevlar, the wings are from Aeronaut Aero-Master and the fins are from multiplex.
    UAV electronics from Arduino and Spektrum. Axi motor
    She weights 1300g with a battery of 5000mAp
    I am very happy with the first flies .
    My Flying shark will be painted with shark mouths painted on the front. But smiling. No teeth like the classic decoration.
    More photos will be sent.
  • The APM is going into an EasyStar now, then it will move into my ElectriStar and if it performs as I expect and proves to be reliable then it will move into this scratch built 4 pound twin boom inverted "V" tail with interchangeable payload options. So far I have been very impressed with the APM. The board took a brief detour providing gyro stabilization for a camera gimbal ... worked very well and now we'll see how it flies. This should prove to be very interesting.
